Diy wheel refurb
Exciting - good price too !
Same colour ?
No going for gloss black
i did the wheel in anthracite wheel paint from halfords the pic makes it look alot lighter
it was the worst wheel in terms of curbing / corrosion out of the 4 i got but got another 2 which are far better
I was going to paint my spare set of silverstones & had a go on one wheel but it came out shocking
took me hours with sandpaper,primer etc just not worth the time & effort for a crap job
called a place local to me quoted £130 for all 4 fully repaired & power coated
so dropping them off at the weekend pic's to follow
130? I'm jealous
First thing first, remove the old primer / powder coat. Wheels are chemically stripped.
Meanwhile I set to work on the centre caps
The caps will be satin black to match the wheels with the badges gloss black.
Will update progress tomorrow when the stripping is complete, they are shot blasted, re coated and lacquered. Then tyres fitted, new Pirelli P Zero's.
Today the preparation continues, with the blaster, before they go on the line for re powdering.
Before:
After:
Ready to go on the line for pre-heat and then powder coating.
Application of the black powder coat.
Good even coverage.
Now they have been baked, time to switch lines and put through for lacquer.
Second powder application, satin wet lacquer applied after this.
Out of lacquer
And finally the finished wheel after the application of the satin lacquer.
Goddamnit you're making me want to get my wheels powder coated even more now :tearsofjoy: in that last picture they look so good! :good:
Reactions: stevef175
You got the same wheels as mine?
Could do them for £85 per wheel,
if you can get them off the car we'd collect, de tyre, strip, powder, lacquer, re tyre, balance and deliver them back to you.
Yeah speedlines, same as yours.
Don't have the money right now, but if you could PM me over some details then I've got them readily available (rather than have to search through hundreds of posts to find this thread) :thumb:
Thanks. They'll be back on the car tomorrow and it'll be off the ramp.
I'm into Engineering - and alot of our stuff gets p/coated. So im at our local place multiple times a week.
Given - most of our stuff is fairly industrial - and not done with the same level of skill and care and attention you provide !
Just saying - i see quite alot of this stuff. Others here possibly not. So your pics are appreciated by many im sure :smile:
