J90RDN
Hi. Strongly thinking of deleting out the ABS (2006 197). Have run track cars in the past without ABS, and much prefer the feel they have. It will obviously reduce a little weight and complexity in the engine bay.
Having looked at the system, there are obviously 2 feeds from the master cylinder to the ABS pump for front and rear, then 4 feeds from the pump to each wheel. My idea is to intercept the rear feed coming out of the master cylinder, feed it into the cabin to a Wilwood proportion valve, then return it to a T piece to feed to the 2 rear pipes. Then simply take the front feed, T piece it to the 2 front pipes.
Can anyone see a flaw in that plan?
