Cullen's cup - Spa trip update
Cullen
Right seeing as the weather is blowing a gale outside and I cant fit my harnesses today I thought id throw up a build thread to keep a check on things.
So where do I start, a brief history of my most recent trackcars as I do love a car or 2.
My all time favourite that I built and drove on track over a 10 year span.
first disguise
Final completed product
2.0 litre abf engine
quaife diff short ratio gearbox from a ex hillclimb car
ultralight wheels
astra gte calipers mk2 rear disc conversion and bias valve
rose jointed strengthened rearbeam
half cage
buckets and harnesses
After this I broke this down to reshell into a mint example, I decided I needed another track car that was cheap to tie me over.
So I went down the clio 182 route and im glad I did, what motors they really are and how fun they are on track.
bought it fairly stock no interior and just 2 bucket seats
Added a cage
Brand new cup shocks and cooksport springs added 3 degrees of camber on front and 3 degree camber shims on the rear
Brembo hc disc' s and ferrodo ds2500 pads along with motul 660
X4 Yokohama ad08r's
fabia splitter
new injectors new plugs full service
and added the leftover stickers for our annual spa trip last year
I then sold this to fund my mk1 project I wont bore you with details im sure your dying to see my current clio :smile:
from that
to this
Now if your still following this is were I had a change of heart and after 12 years of mk1 ownership I really wanted something new so I stayed classic but went rwd.
Short story on this turned out to be an absolute dog of a car bodywork wise pulled the rear subframe through the body after 4 track days and I broke it for parts
Right this brings me up to date with my current car
Clio 197 cup
A car that ive known about since 2015 and even did a lap in it at Bedford auto drome in it
CAT D repaired by the friend who I bought it off, he owns and runs a very successful body shop he has had the car since 2014/15 and it was also serviced in its time by my best mates garage so I couldn't ask for a better looked after car.
39,000 miles
belt and dephaser done aswell
quaife diff
4-2-1 manifold
decat
and cat back with slashed pipes
rs tuning map 210hp and similar torque if I remember correctly
and dodgy stickers that im not a fan off.
Picked it up for the sum of £2800 which with the mods im happy with
car needed a balljoint new pads and discs and service
The night I picked up the car
First on the list was to peel the awful stickers off it and what a pain in the arse that was took nearly a day including getting it clayed and washed after.
The after pics will not upload for some reason
After getting this annoying task done I set about a little order spree
I ordered
Brembo hc front discs
mintex F2R pads
standard rear discs
a complete driver side hub
new wheel bearing
Passenger side hub had been done last year
track rod end
x4 Yokohama ad08r's
20mm spacers
half cage
clio cup splitter
Trial fit of the rollcage.
All loaded up to go to my mates garage to fit all the new parts.
When I resize a few more pics ill update the thread.
Reactions: Beany and Sean197
Car during its new parts install
Few pics of the cage installed and one with the seats.
The wheels were kerbed and faded so I set about giving them a diy paint job
new colour kia titanium silver
And finally a few pics of the cup splitter added which I cracked slightly didn't realise how hard and brittle these splitters were.
Future plans for the car involve a full strip out and a cup racer inspired build
Off to SPA Francorchamps for a double header trackday in 14 days time so ill update as and when I do stuff or trackdays.
Subscribed [emoji108] previous cars look awesome! Look forward to seeing what you do with it
Reactions: Cullen
Sounds like a good buy with that spec and the Recaro's. You'll get a few quid back on them if you decide to change to some fixed seats.
I'm still deciding on going the full track route myself.
The recaros will be for sale after ive purchased a trailer in the upcoming months, loving having afjustable seats with normal belts when you do the odd sunday drive.
I think these cars can be full track while retaining the comfort, if done correctly
Update
Few new additions to the car before we headed off to spa
First off harness installed
Drilled through the seat raisers as they are thick enough and put spreader plates behind, this meant the buckles were easy to adjust and i could keep my existing seatbelt.
New torque arm bush
Old
New
New sunstrip
And a random pic as it looked good
The Big Day
SPA FRANCORCHAMPS
We set off on the sunday about 4.30am to catch our 7.20 train, not many pics just a mainly uneventful travel to spa, got to the hotel de la source at about 2pm and swiftly jumped on the beers.
A few belgium jupiler's later and a bite to eat
Day 2
And the first of the double trackday
All lined up and ready to go
Full specced clio 182 caged coilovers etc
My cup quaife diff caged etc
Astra gsi fully stripped quaife diff 290hp
Mk3 focus rs kw v3's ar1's 420hp
And not in shot
Caged and coiloverd e46 m3
Few check overs before sighting laps
Sighting laps were long as anyone who has been on track will know, i think javelin overbooked the first day as we didnt get on track officially til 10am ‍♂️
None the less we had a full day of sunshine and dry track best ive seen spa in 3 years now
S26CUP flying up eau rouge
Holding up a slightly faster car
The old man getting in on the glory
The day went faultless for the clio overtaking some much higher hp cars and hussling a few others out the way it sure wasnt the slowest by a long shot.
On the other side of the garage tho it was a different story for my mates m3
After 3 laps this happened
Grey smoke overfueling you name it this car had it that day,
After alot of headscratching and diagnosing we werent coming up with much we stripped everything down, checked breathers, fuel, code read it and still nothing exactly the same everytime he went out.
Luckily he knew a bloke at ringspares at the nurburgring so he shot off for the 1 1/2 hour trip to get diagnosed, in the hope he could be on track for day 2.
The astra had a cv boot split so he set about getting it sorted in his lunch break.
The rest of the day was superb lap after lap getting better and better, i hardly took any pics of vids as it was nice to get loads of track time in before tomorrows rain came.
We ended on track at closure time 6pm and headed for another... yep you guessed it. This time on the rooftop bar over looking eau rouge.
Cars getting a well deserved rest
Ended day 2 with more food and drink
Day 3
And not a good start for the bmw
After one lap it pressurised blew the breather off sent oil over the manifold and caught alight in the pits.
Safe to say that was the end for the bmw
The rain came and went all day but the track was surprisingly grippy, mainly off line as there no rubber layed down,
The AD08R'S are so good in the damp and wet conditions.
Few pics
Getting a bit squiggly at la source
Again not many pics as i spent alot of time just lapping getting quicker and quicker and finding the limit in the little clio.
I had read up about wet track driving and how its best to stay offline where you can due to no rubber being layed this making it greasy, i did all my braking lines offline and wow what a difference in grip there was i was hooked and overtaking alot of fast cars with this knowledge.
I felt with the cup shocks and springs and no rear anto rollbar it was better in the wet alot more forgiving and not as titchy as my previous years in coilovered cars.
The car ran faultless again until 4pm when danger struck.
A dry line had appeared just before 4pm and after lapping spa in the wet confidence in the dry was even higher than day one, but the clio had other ideas coming.
Just as i came to the last corner i thought i missed 5th but managed to get into 4th, coming upto the chicane i put my foot on the clutch to downshift to 3rd then 2nd and there was nothing, no pedal just air basically, coasted it into the pits were i got towed to our garage.
Bollocks to ya i was fuming the ol girl had done so well and to let me down with a slave on the last 1/2 hour of the day was a pisstake.
After the storm had blown over in my head we started the car off the starter motor in 1st and got back to the hotel.
A beer was swiftly downed and the RAC euro recovery was sorted.
Now for those of you who havent broken down in europe let me tell you something, i will never moan about breaking down in britain ever again.
The cars when broken in europe have to go and be looked at by a garage to assess the damage then they have to weigh up the cost of the vehicle as they can agree its not worth fixing and its not worth getting it recovered home, thus meaning you would have to go back out to europe with a trailer and bring your car home.
Lucky for us this didnt happen the cars were deemed expensive enough to be recovered home,
It didnt end there tho, the cars wont be recovered home til the 18th april.
To be continued.............
Epic update. Did you take out extra Euro breakdown cover before traveling? That’s awful them not recovering you until the 18th!
Cheers
Yea took out extra RAC cover, my mates bmw has just randomly turned up today without warning, so the clio could be home any day
Reactions: Big Ben
Sounds like a great couple of days, hopefully the problem at the end hasn’t put a downer on the trip. Spas somewhere I really want to go when I get a chance.
Reactions: Cullen
We were at Spa tja 1st of april, seen your car.:thumb: Great day, well organized.
Amazing weather on that monday couldnt of asked for better.
I was meaning to get round to talking to some clio owners see whats good and whats not but i couldnt pull myself off track
Reactions: Slowride
Some good news and some not so good news
The car came back early from belgium which is a bonus but they fooked my splitter so a complaint will be going in :worried:
Seats have been provisionally sold new owner is coming for them tomorrow.
Looking sorry for itself
New genuine clutch and slave has turned up so hopefully that will be the next update.
