Confused with Fuses
Status
Not open for further replies.
Hi
clio will turnover but not start - battery is fine - has 13.4v and nearly 400ah
I am trying to locate the main fuse board on my R27 F1 clio.
reason being I need to check the fuse for the fuel pump.
I have no idea where the main fuse board is and where this fuse would be located.
The other thing i could check is the Fuel pump relay.
Any help would be greatly appreciated.
Paul, have you checked the crank sensor?
Yes I located it, took it out and cleaned it up, but made no difference. I have ordered a brand new one that arrives in a couple of days. So will replace completely and try again. If it isn't that, then I presume it could be fuel pump or fuel pump relay?
I assume the end of the sensor was ok? A friend of mine had it recently where his clutch cover fell apart and took the end of the sensor out.
I've never heard of one suffering with a fuel pump problem. But I guess it wouldn't hurt to check.
you can hear the pump prime as you try to start the engine...
fuse box is under the second air inlet on the passenger side...
Status
