The only difference I would take a guess at would be the higher ambient temperatures in the countries this has happened in, so the oil could be running thinner, what viscosity oil have the guys been running? Might be worth contacting the oilman off here to see if he would recommend a more race orientated oil incase the oil pressure is getting too low when its hot causing the starvation
not heard any reports of bottom end bearings going....its usually the con rods that fail!!!!
the problem is that the crank bearing turn and close the hole that give oil to the con-rods bearing...
see that worrys me..
[youtube]GQh44Y66sF0[/youtube]
...my engine randomly does this..
So it's spun a bearing and blocked the oilway?
If it goes quiet after that i doubt its the crank, more of a sticking tappet.
The last pictures are from an engine with motul v300..
Pressure gauge can help us?
Aerial connections | Clio 197 Area | 2 | |
Connects 2 Adapter | Interior and Audio | 0 | |
Renault F4r Maxspeeding forged h-beam conrods Arp bolts *more parts available* | Car Parts For Sale | 3 | |
Sold: Megane 265 OEM pistons & conrods | Car Parts For Sale | 2 | |
Con rods bid for freedom | Gallery | 4 |
