I’ll keep that offer in mind mate. If I’m up that way can I drop you a message?Nah otherwise I’d do it for you, I’m Notts, j28 M1
Not really, it’s very tight, when fitting mine with adaptors etc I removed the glove box, five torx t20’s, one tip centre about 3” inside the glovebox, three behind trim at the top (comes off very easily!) and the remove the left hand side plate, again, unclips nice and easy, then it slides out, there’s a few plastic clips around the glove box but a firm tug and it slides out@Dumdum dunno if I'm being thick, I've installed radios before. I just can't get my new Pioneer HU to "click" into place. I bought a Pioneer DAB unit (contrary to what I said earlier), a connects2 clio faceplate adapter. I've connected the stereo and it works fine. It feels like it's pressing against cables at the back although I've moved them out the way, and Pioneer unit is shorter than the stock one. Am I missing something?
As you can now see the side of the stereo plastic slot for want of a better description I attached everything bar the cars iso leads and fed them all through and used the end to pull them all through, the control units etc all fit up the side of the heater controls between glovebox and heater controls...
It all laid up the front nicely be the glove box only has the banana shaped opening parts nearby, all fitted lovely
No, I am not sure which part gives you that idea as I dont mention putting screws into it??? you use the normal cage that comes with the radio, the glovebox removal is to allow you to pull the leads through the side at the back of the slot, then it clicks in like normal, the leads behind are what’s stopping the stereo fitting far enough inSo you need to screw in the stereo from the sides to fix it in place?
It wasn't that clear what you meant tbh!
Yeah I'm using the cage that came with the Pioneer HU as well as the plastic surround.
I'll see if I can pull the cables through via the glovebox tomorrow, cheers
The issue with aftermarket speakers is they are generally designed to work with subs and don’t tend to perform well in a leaky door environment, so I would recommend sound deadening and sealing your doors to get the most out of your current speakers as they are far better suited to the environment they are in and then you will optimise bass from any speakers you then choose to upgrade to rather than throwing them in and potentially getting a worse sound that’s thin and watery than it is currentlyHi....what are best speakers to get now that I changed my head unit to a 4 x 50w?
A hair dryer is essential to soften it and get it to stick better and form to the contours of the door... and you need to degrease the inner and outer skins as it needs to stick to work whatever you use generally has adhesive quality’sIs it easy to apply sound deadening to the doors of my 197? What is the best deadening to use? Is it something I should try myself or get a professional to do?
Many thanks
after further research into more bass, the best and easiest way i think im going to go down is to get a flat under seat subwoofer. Boom!Great, thank you- so best to do soundproofing, then upgrade speakers then if needed add a amp.
thank you
If you go into audio settings on your headunit, see if there’s a section for hpf (high pass filters) this will then cut sub bass frequency’s from the front and rear speakers and allow them to sound better and suffer less distortion as a result, I’d start at 80hz and set the lpf (low pass filter) to the same for the subwoofer preout also (Some with limited preouts may need the rear/subwoofer set to subwoofer to feed the under seat unit and then you will also have a level control on the headunit if equipped)after further research into more bass, the best and easiest way i think im going to go down is to get a flat under seat subwoofer. Boom!
Car Audio Fitting Kit (no longer selling) | Car Parts For Sale | 4 | |
Audio installer - Midlands | Interior and Audio | 3 | |
Got a few audio questions (200 Cup 2009) | Interior and Audio | 9 | |
Interior Audio upgrades | Interior and Audio | 5 | |
| G | New here looking for audio advice | Interior and Audio | 17 |
