Right OK... well I have taken the front panel off the instrument cluster and looks like you can easily change over the dial sheet which may mean buying a complete used 200 instrument cluster. You would just need to take the hands off to allow the sheet to be taken off.
I will see if there is a part number for it so you can retain the same instrument cluster & correct mileage by changing just the 200 (yellow) dial sheet.
Update:
The dial sheet cannot be purchased separately, only as a whole unit so means looking out for a used 200 unit. Looks like they can be picked up for £20+.
Update:
I was thinking of the same thing, seen one lately at a Breaker, but I prefer the clean look of the 197,the yellow could get annoying on the eye if the sun catches at odd angles. IMO.
