Clio 200 style R3
Im running 7700rpm on standard bolts.
RS Tuning run 7800rpm on their stage 3 which is uprated cams but still standard bolts to my knowledge?
Car looks very nice by the way!! Love those wheels :smile:
TDF told me they would only raise my limiter if it was fitted with arp rod bolts, as the cup racers are.
Been a few failures from members on here from STD items too!
Hello friends I'm glad you like the car, has what is called a stage 1 and without any problem.Of origin you can climb up to the maximum 8000rpm without that then you have problem in the engine
Supplied and fitted about £280 IIRC from TDF, obviously you have to drop the sump so you'll need to put an oil change on top of that.
