Raptor6767
Gold Member
If he didn't notice the difference with the cams than it might be the timing problem.
I had that problem at first.
Here was your graph Litchy, 210bhp and 175ftlb - I don't know how you can say zero real world difference? For all intents and purposes it's a very similar graph to mine when at RST.
However I wonder if yours was perhaps reverting itself overtime like mine was? With the Shricks being a wilder cam I suspect the MAP sensor was having just as much of a hard time as mine and with the way the Sagem applies closed-loop trims globally it could have been happening on yours..... I didn't feel mine go from 215bhp at RST slowly back down to ~200bhp when the standalone replaced it. Stock ECU is just a pile of wank.
Well i totally disagree. For me, I can feel the difference in how car drives on the road in every aspect . And in standard form they are very poor imo. Even with just a
map they improve no end. Think had enough cars and modified enough of them to tell
if something works or how it drives.
And as as for standard car keeping up with you and been no
differnce comes down to
other factors aswell.
Then I wouldn't be surprised if your ECU was as I said slowly reverting then. When a standard car dyno's about 185-190bhp and about 155ftlb at RST, then no way you'll not feel 20-25bhp and 20ftlb back to back. I know the gearing on mine changes things but I am pretty sure it would be a full on rape-a-thon against a stock car. My car stock bored me to tears frankly.
Not sure how you can say your car drove best standard either, more evidence then that Shricks likely need a standalone to run properly in that case.
i did a few moons ago. Unfortunately you have to drop the subframe to get easier access as well as being able to rotate the roll bar clamp forward to remove it from a retaining slot in the subframe,once you've removed the clamp bolt. . Maybe better to wait until you have to drop the subframe for something else. Although I have got this down to fine art!!Anyway back to build thread - thinking of ordering the powerflex front anti roll bar bushes. Has anyone fitted these ?
For Sale: Clio 200 Belts | Car Parts For Sale | 3 | |
For Sale: Clio 200 Clocks | Car Parts For Sale | 1 | |
| M | Clio 200 | Clios For Sale | 0 | |
| A | Clio 200 cup headlightwasher relay remove | Clio 200 Area | 2 | |
Sold: Renault Clio Sport MK3 197 200 Clio Mk2 V6 Airbox Intake Induction | Car Parts For Sale | 0 |
