I chose to go with the Genuine Factory Cup Racer X85 Exhaust - consisting of decat manifold, sport cat and cat back lightweight race.
Cat-back weighing only 6.8KG
Cat weighing only 4.65KG
Cup Racer Cat doesn't come with a lambda sensor so I cut a hole, chose a 45 degree M18 x 1.25mm 304 stainless boss and welded it just after the cells. New lambda sensor too.
The full system has since been installed & tested and reports are it is very loud, however combined with the race cat it feels very smooth unlike a full decat as before which felt rough. There is no noticeable flat spot any more.
Was this car at the last PistonHead get together by any chance, at Merc World?
Hi just had a look through the thread! Very impressive, I'm not going to the lengths you have but I am in the process of stripping my interior taking out the carpets, plastics etc my only problem so far is in the footwell once I remove the sound deadening is the depth you loose to the pedals I see in the pics above you have something there could I ask what they are and where you got them from?! Cheers
Sent from my iPad using Tapatalk
How loud is the Cup exhaust (db) - for track days and what not?
My brother from London was there as a birthday present, and he sent me pictures of your ride back to South Africa and as a Reno nut, I wa like yeah nice car man!Sorry, not been on in a while. Yes that was me ;-)
WOW mate thats brilliant work it looks fantastic!
what you came up with at the end ?(car weight/ engine output)
I see.Not finished the build yet. Are they ever finished thou?
Engine is standard currently with the aid of the R3 Carbon airbox. I am strong believer of saving weight where I can first before plowing into costs for engine upgrades that sees very little gains on a N/A engine.
Weight is unconfirmed as corner weighting is happening in the next 6-8weeks with suspension & kinematics.
Thanks.Did you notice much of a change in balance when you stripped the weight out of the back of the car? I found the car great fun as it is but wonder if it may become tail happy making the back end lighter....
Thanks for the info. I suspected stripping would also need some suspension tweets. I am going to enjoy mine as is for the season and have a think in the winter. Failed the mot o. A ball joint so that's first on the list...Thanks.
From removing the back seats I doubt you will feel any real difference in balance unless you are pushing the car and looking out for it.
On this occasion my Clio was already stripped when I bought it so can't comment on what it was like before.
It does however like to oversteer occasionally but that's mainly from lift off but the lack of weight at the rear will play a part in exaggerating it slightly.
Setting the cars weight transfer correctly and proportionally with coilovers allows to iron out any irregular weight in the wrong places.
