Lowering the column - It takes a fair pull on the column to get the brackets over the front location pegs. We used m8 penny washers, just enough to allow the column to go back over the location pegs (hope that make sense).
Hi @krash67
I used the Renault CLIP interface and associated software to remove the relevant airbags from the car, or tell it that they werent present so that it doesnt look for them. There doesnt appear to be a way to remove the airbag ECU from the system totally, however i did get to the stage where I was able to remove the connector loom going to the rear of the car, and then tuck the ECU up and out of the way behind the dash.
Happy to help you do this if you like, depending on where you are!
| Misc Plastic | 6.6kg |
| Carpet & Mats | 7.6kg |
| Seatbelts & Intertia Reels | 6.6kg |
| Roofliner | 1.4kg |
| Side Curtain Airbags | 2.0kg |
| ISOfix Bar | 2.4kg |
| Foam & Sound Proofing | 7.8kg |
| Misc Tar | 4.3kg |
| Toolkit | 0.5kg |
| Parcel Shelf | 0.4kg |
| Rear Bench Seat | 4.6kg |
| Rear Bench Backrest | 13.7kg |
| Passenger Seat | 21.9kg |
| Drivers Seat | 24.6kg |
Thats a bit far mate...I'm in Sussex!
Once you have CLIP installed, plug it into the ODB port, and scan the computers. The airbags should all be in there "fault" condition before you do this (no resistors connected etc), and you should see under the status section what is wrong. You can then enter the diagnostic mode, and see the required status of each airbag. On the left there is an icon you can click to reconfigure these requirements, which is fairly straightforward, then validate and accept, restart the car and bingo. If you get stuck let me know and I can talk you through it. Next time I have CLIP attached I will try and do a guide of some sort.
cheers, clip hopefully turning up tomorrow and will go over it at the weekend. I'll pm you if i get stuck.
wana do mine for me aswell?
i also would like to remove the air bag light! i have a safety devices bolt in cage and the same seats as you, ive still got to remove the cage and paint inside how come you havent removed none of the unwanted brackets in the rear?
No problem. Remember to make sure you install it on a 32 bit laptop.
Clio 197 Track car For Sale | Clios For Sale | 1 | |
| C | 2007 Clio 197 Track car - Cage, Quaife, Buckets | Clios For Sale | 1 | |
Clio 197 (Track Spec) | Clios For Sale | 0 | |
For Sale: Renault Clio RS 197 200 Wheels 17" & Tyre Package Track Day | For Sale | 2 |
