Litchy, airbox won't be to limit power on cup racers, I appreciate that it's gains are not fully tested across multiple cars for verification, but they used it in the R3 maxi which was 227bhp (230cv) so clearly no restriction at stock power levels.
RS must have had a reason to do it on Cup Racer, R3 Access and R3 Maxi.... Just like for the 2009 spec Maxi Evo they changed ait again. I would conclude the V6 airbox is at its limit around 225bhp ish.
I think the comparisons with the cup and R3 are less relevant given those cars share very little with the road clio which like I said is already at capacity around 200bhp anyway.
Disagree there;
Cup Racer is the same engine, just different exhaust system and obviously the airbox.
R3 Access is same as above but runs a different inlet cam.
R3 Maxi is the first iteration that stars to deviate. Exhaust manifold, cams, pistons and injectors.
R3 Maxi Evo is the only one that's prohibitively expensive because it has a different crank and head. Also has rods and solid lifters. Then vs the older Maxi it has different cams, pistons and airbox again!
Was the car mapped to suit V6 airbox or dyno'd with original map instead?I guess I can only go off my own experiences having fitted one some years back and on RST well respected dyno, it made nothing more or less than the standard system.
R | Clio 197 water in footwell | Clio 197 Area | 13 | |
C | Clio 197 alternator | Clio 197 Area | 1 | |
S | will a 197 diffuser fit on clio 200 | Body Work and Exterior Lights | 16 | |
Clio 197/200 Powerflex Poly Engine Mounts (various) | Car Parts For Sale | 6 |
