After unsuccessfully attempting to route a power cable for my amp today my car (1.4 dynamique S) has thrown up a service light, a check injection light, a check emissions light and has gone into limp mode. :001_unsure:
The power cable was pushed through the same grommet which houses the bonnet release and a host of other wires. Could touching any of these wires cause the problems? I assumed that none were to do with engine management?
The power cable was also routed behind the plastic trim at the bottom of the passenger side of the interior to the boot, again is there anything here which could cause the problem?
Finally, the only thing I really touched under the bonnet was the airbox, could any sensors have come detached from this causing the problems? (MAP sensor, ignition coils and spark plugs are all fine).
Any other ideas for how to solve the issues welcomed!
TIA
TIA
