Hi there, I'm a new rs197 owner and I started the car today and it says check emissions and spanner and engine management light is on. What could this be? I have a full tank of unleaded fuel think 95 and it has milltek exhaust fitted.
Sadly no code reader so can't get that for you it sounds very much like the exhaust is blowing and seems to be from front end like manifold or the downpipe? Possibly but can't say if it is as new to renaults.
It wasn't on before today but came on when I started car to go from supermarket car park to petrol station and has stayed on and I've just done a 100 mile journey
Had this myself in the last few days running a ktr and a decat had my friendly local plug it in, no fault as such just went over emissions so threw up the fault anyway reset now and I put a £3 O2 spacer in the down stream lambda did a few miles today so all good cheap fix. I looked at all the options and basically u need to plug it in to know what to do next.
however if the car is still running well its probably not the upstream lambda
So I just need to plug a OCD reader in to the car and locate the error code? That way you guys can direct me to the problem? Is there anywhere in Leeds that can do this for me?
the car is off back to the garage i bought it from this week for full diagnostic check of the emissions and any work thats needed will be carried out under warrenty
