burrellbloke
If you are considering tweaking your suspension then a set of Gaz Golds will have adjustable top mounts so you can adjust ride height, camber, and dampening. The price of a new set of B14s and additional adjustable top mounts is probably similar to a set of Gaz Golds.
If you want a more compliant ride on Gaz Golds that will deal with bumpy B roads do not go for stiff springs and get a spring rate that is suited to fast road rather than track.
