Hi Guys,
ive had my Clio for 5 years now. Done about 55,000 miles with it all good so far up until a few months ago when I tried braking whilst doing about 125 miles and the the car wouldn't stop as it should.
The brakes initially started working and a second after the pedal went further down and it was like I had released it( something like the abs kicking in)and then it started started braking again. Since then it constantly does it at high speeds and just doesn't feel right. I've bled the brakes twice by myself as well as in Renault themselves but there seems to be more air in every time.
When the car is standing still with the engine on the brake pedal (once pressed makes a hissing noise).
Now I would like to point out that the discs are pretty new and so our the pads and brake fluids.
Might it be the brake pump?
Any suggestions on what it can be as I just cant figure out the problem.
Thanks a lot
Thanks a lot
