Joec1996
Gold Member
brake disc damaged
Hello people , just brought a 197 I need some advice please if anyone can help I recently just got my timing belt and water pump changed along with a cv boot. Everything seemed fine until I drove it 5 minutes down the road I started hearing metal on metal noise, I then pulled over noticed that my Near side brake calliper and brake disc were rubbing together making deep grooves into the disc brake. I then tried too move the brake disc with a cloth as it was hot and the brake disc was moving and was really loose. I got it back too the mechanics and they didn’t tighten where the wheel bearing nut Is and the nuts what hold brake disc and in my opinion it’s damaged my brake disc they’re saying my brake disc will be fine it will wear in but I think it needs too be changed, anyone else can give me an opinion and the mechanics I took it too have also used a zip tie for the cv boot is that okay ?.
I haven’t got the best off photos as I’m currently at my partners and my cars back at home.
