Hi all,
Long time member... finally got myself a Clio 200, after wanting one for a long time. Purchased from Ron Feldman who is an admin over on ClioSport, great guy, the sale went very smoothly. This thread is more for my own records, but maybe someone will find it interesting! Also, would appreciate some input on the 'plans' section
Boring introduction:
Reason I joined back in 2012 is my first car was a little 1.6 Clio III - great little car until my now wife decided to smash it into a brick wall (she was fine, the Clio was a write off). Always loved the Clio 200's, but were a bit out of my price range at the time. I then got a C30 T5, which was fantastic, the 5 pot sounded great, but the car was so heavy, it really didn't suit the back roads of Suffolk where I live... so in 2016 I moved onto a 2007 Cayman 987.1 (Picture: https://imgur.com/7jfcvjd). I sold the car in December 2019, partly because I felt I'd 'scratched the itch' (even though I definitely hope to get another Porsche in the future), but mostly because I wanted to start doing some track days, and didn't really fancy doing so in the Cayman. It was a truly exceptional car... they are a bargain for their current money imo. Couldn't get enough of the 6 cylinder howl (Carnewal GT exhaust), and handled / gripped incredibly well with a proper setup and some Michelin PSS. Anyway, onto the Clio! I picked it up a few weeks ago, and have been loving it so far.
Spec:
Plans for the car:
I'm still quite undecided to what extent I want to track-prep the car. Having never done a track day in my life, I don't want to go crazy with the prep, but for sure I will do the following, in order of important/priority:
Issues:
- I'm getting some creaking/knocking from the front right wheel when at full-ish lock, which I assume is from a ball joint, but Ron had spend over £1000 at AW Motorworks last January giving the suspension a refresh (ball joints, top mounts, track rods etc). Could the car really have gone through a ball joint in that short time? Hopefully I will get this sorted soon, as it's the only slight problem I've got. All the other common issues are fine (exhaust manifold, gearbox etc).
- H&R Springs - finding them way too hard for bumpy B-roads, perhaps they will shine on track, but I was hoping the car would be better on the back lanes around where I live. Perhaps I was spoilt by the Porsche, or perhaps the dampers are a bit shagged on this car.
Pictures:
First pic is by Ron, but it's a cracker!
Spec:
- 2009 Clio 200 (FF with Cup pack)
- Glacier White
- Black Speedlines
- 84,000 miles
- Akrapovic Evolution Line Exhaust System
- Recaro yellow-dot buckets
- Retrimmed steering wheel by Snappy
- PMS spacers (plan to remove)
- H&R lowering springs (maybe keep, maybe change, maybe coilovers)
- K&N panel filter
- Stock map
Plans for the car:
- Spare set of wheels with semi slicks (AR1's or Cup 2's, undecided)
- Brake pads (currently planning on DS1.11 on front, which I will swap back to Brembo between track days, and DS2500 on the rear permanently)
- Brake fluid (seems like everyone uses RBF660)
- Brake discs (Brembo HC UV all round).
- Braided hose lines - are these a must for track? Seems worth it for £70ish considering I will be doing new fluid anyway.
- MAP sensor mount (cheap mod, and looks nice
- Refurbish / service the calipers (brakes seem to work fine, but I imagine a clean up, with new seals would help... I'm very much a weekend warrior when it comes to working on cars, so hopefully I can find some good guides on completing this job)
- Powerflex bushes - not sure which to go for, I see most people install the engine mount one, but need to do some more research on this.
- Lowering bracket for drivers side Recaro. Any recommendations on who to buy from?
- Remap - long way away, but thinking of going up to see Chris at EFI. Heard great things, and wondering if the Akra might unlock a few more hp.
- Full service incl. gearbox oil (already completed this, will do a separate post on this thread for that)
Issues:
Pictures:
. The pooch isn't too sure on it.
