///M
Gold Member
Way things are going mate I might settle for £6k lol
Think of a number and double it time!
Hope you've built in some contingency mate!
Worth it when it's done.
There's always two budgets Mes. The original budget that the missus has agreed to...Think of a number and double it time!
3" downpipe and de-cat pipe going on as well as 630cc and re-map. No turbo upgrade yet!250 turbo and 630cc injectors too thenMake sure you go for the 3" downpipe and linkpipe - mine were 2.75" and combined with the clio cat-back were holding the power back to around 280bhp.
I can have a simple meg conversion Jimmy no problem well inside my budget.And so it begins! Hopefully costs will be kept to a sensible amount Ben and you won't have to keep forking out - I imagine that's a fear for anyone who's going down this route.... Although I'm sure there's enough info out there to know what to expect - good or bad![]()
It's the spending now on extras to save labour down the line that's going to put the pinch on. One things for sure though mate. It's should get down the road pretty quick once it's finished![]()
Don't fancy a dump valve. Loving the description of your recirc akra combo thoughdont put a dump valve on. Just a upgraded recirc so it holds the boost better and you get some flutter. Sounds like you run over a turkey.
unfortunately the akrapovic on mine sounds like darth vader having an asma attack so i cant hear it that well
Don't fancy a dump valve. Loving the description of your recirc akra combo though![]()
I'll kill myself if mine sounds like that jetliner..!Atleast it doesn't sound like a 747 jumbo tho
o right. I was told to that it holds the boost better especially when mapped hense why i have one fitted.Recirc valve doesn't help hold boost, the actuator does. Recirc valve directs boost away from the compressor when off throttle to stop compressor stall and subsequent damage to the compressor. It's basically a dump valve except it doesn't direct boost to the atmosphere like a dump valve does.
im away till Friday Mes..will sort something out when I get back..many thanksI'll need some photos mate!
LOVE your new avatar. Wheels look fantastic in that colour.
Cheers Pav. How'd the Witch go on the run to Wales?from what I heard the recirc valve is good for holding the boost.even Paul said it when I was at RST..i would spend my money on one if I had the money..still waiting...but a standard one is fine too Ben...
And the top up cash budget that I shamefully hide from her so I don't get my nads ripped off![]()
brilliantly..she is spot on now..touch wood..going back home tmr so may give her a little beatingCheers Pav. How'd the Witch go on the run to Wales?
