I’m not missing the revs Davinder. Once mapped I doubt I’ll give them a second thought!! £5k for a charger on my high miler didn’t add up
I think a meg conversion is much more realistic for my situation, unless I win the lottery! In that case it'll be supercharger/meg conversions all round for everybody![]()
I'll quote you on that when you've finally won the lottery!![]()
Not fair right....
Mines turbo charged already![]()
Not uprated the con rods mate. My issue is with the engine having too much power that the front wheels can’t cope!glad it didnt cost you too much
im sure you should be absolutely safe with let's say 270ish mark Ben..that's what a 225 turbo is good for..have you upgraded your con rods too??that's a bit reassuring for me as i did..
Exhaust vibrates a bit. it’s probably the diffuser which I’ll sort at a later date as it’s intermittent and hard to trace.
Didn’t make it very clear did IAre you sure it's the exhaust and not the heat shield of the diffusor? Mine started to rattle @ ~3500 rpm and I had it taken out and replaced by some of this self-adhesive heat sheet/mat. Worked wonders!
Btw, I've got word that some people are actually driving without any heat protection at all and their diffusors didn't melt so far.
really? mine wheel spins in 3rd dryif your car makes 270 safe then go for it..i have exactly the same set up,as you know,and it's perfectly safe..the only time i get a wheel spin is when i floor it in 2nd and 3rd and when it's wet![]()
