Best windscreen washer jets?
One of my washer jets has packed in for no reason and was fed up with them anyway because there pathetic!!
Just wondering if anyone knew where i can buy some decent ones from!?
I bought a couple from eBay that others have recommended. I think they're from a C2. They weren't great those because they wouldn't sit flush to the bonnet.
Did you know that you can get a pin and move the jets to a different angle? You might find that yours are pointing at the bottom of the screen. They're very easy to remove and check, you basically just pull them out of the bonnet. You might want to clamp the hose those otherwise they will disappear down the hole and you'll need some needle nosed pliers to retrieve!
Id be interested in this too. I fitted 'fan' style washers to my last car and they were a vast improvement over the 'jet' type that it was fitted to it. Currently looking for suitable 'fan' type for the clio.
I'd be interested if anyone has found some, the jets are a bit pathetic would like some fan types that are suitable to fit the clio
