Power flex upper torque arm will be my next job. Which one though they do a black "race" one
Are the standard powerflex ones a lot better than the original Reno ones?From the powerflex website; the black ones are 25% stiffer and 80% more resistant.
Unless you don't mind more vibrations I'd just stick with the standard powerflex one, I think the black ones are intended for track cars where the roads are perfectly smooth.
Loads of really good information gents thank you!
Given I've already got the uppper torque arm poly insert I'll take a look at the other poly mounts and strongly consider the TS manifold.
Would an engine damper help in the same way as these stiffer mounts?
Brill, I'll take a look at the lower mounts.
Is this the manifold I'm looking for?
https://www.ebay.co.uk/itm/182194730240
Is that linked manifold straight fit, or do it need some kind of modifications for perfect fit? It may give some little performance punch because it lacks precats.
Not bad price..
Are all these "Toyosport" ? because no any brand in ebay links..
Do you know will it pass mot emission test without pre-cats..?
Mine did, no problem.
Right, I've got a TS manifold and bush inserts now.
Has anyone heat wrapped their manifold to reduce noise? Will provide some padding if it ever knocks against the subframe too.
The thing is the vibrations are only an issue when idling and they die over time anyway, so it would be worth getting the gearbox, lower engine and torque arm inserts. They really do make so much of a difference.Beginning to hate this forum now @sevenfourate, my cars going to have the K Tec manifold fitted end of the month reading this its making me think I should get some powerflex goodness going on at the same time... What would you all suggest for the least amount of vibration...
| S | What exhaust is this? | Engine, Gearbox, Exhaust and Air Intake | 0 | |
Exhaust manifold blowing | Clio 197 Area | 3 | |
| H | Replacement flexible exhaust couplings | Engine, Gearbox, Exhaust and Air Intake | 3 | |
| K | Scorpion 200 full exhaust system | Car Parts For Sale | 4 | |
| K | 197 exhausts | Engine, Gearbox, Exhaust and Air Intake | 2 |
