Yip... When I changed my gearbox oil to Ravenol, I was hoping for miracles... Who knew the fix would be that cheap and easy?
Thanks guysJust to check any things to do after disconnecting the battery other than the radio code?
Check post #37Really interesting thread my 200 has always been a pig to get in gear when cold. Iv noticed the car goes into gear fine when the engine is off so I tend to select 1st clutch in and start engine, hence why I'm sceptical mine is a linkage issue ..feels more like a clutch problem, but this is worth a shot I guess. Any pictures of this ?
Apologies in advance for being pedantic.. but I will only get it wrong if I don't ask exactly what to do :book:
When I look down the side of my battery I can see what's in the 2nd and 3rd pic. Are these what I lube up? If so, how - just spray around?!
Or is it the very end things in the first pic that I should be lubing (can't see them down the side of my battery). If it is these, what do I do?
Cheers for any help!
I found it was the (very end things) [emoji23] that I lubed which made all the difference, if you expose enough area by removing the battery also the battery box and or the Airbox which really isn't that difficult, it will make things a lot easier to see what you're doing.
Anyone who tries it should post their input whether it's worked for them or not. Always handy for others to see.
