im aware that some models of the 197 have a switch on the drivers side of the dash that's hidden when the door is shut, that can be switched to de-activate the passenger airbags.
im assuming this isn't on our car due to it being an R27 and having the Recaro's?
I would also assume that the main loom behind the dash is the same across the full 197 range, so the plug for this switch should still be behind the dash panel on our R27, can anyone confirm this atall?
if so, has anyone retro fitted this switch and panel atall?
we have changed the Recaro's over to the more standard 197 seats short term, and like on the earlier 172/182 cars, you could fit a baby seat in the front and de-activate the airbag for this reason.
we would like to be able to do the same, which the point of this thread is to see if its achievable or possible?
cheers
cheers
