After a short trip in my 197, completely out of nowhere i get ABS/ESP and SERV light come on and a electronic fault warning on the dash. Also my brake lights no longer work (bulbs are fine) but all other rear and also front lights are working still. For this reason im assuming the issue likely isn't an ABS ring as other have mentioned however i have checked over the fuse panel and cant find any blown fuses related to the ABS/ESP. I have scanned it with a cheap amazon scanner but it dosent show up any codes, so at this point i'am completely stuck so any suggestions of things I should be checking would be massively appreciated.
