I guess in the end it's down to what you want from a mod. For me it's analog, linear and consistent throttle response. I'd like nothing more than convert my throttle body back to cable.
you are right, I did neither own a 64mm TB nor a sprintbooster and therefore my statements are theoretical assumptions. however, these are facts:
- an additional electronic device that refactors a signal to the ECU needs processing time. This means it can't accelerate the input you give with the right foot. (as mentioned, it might certainly feel like it does due to the more aggressive mapping applied)
- the pressure limit of the air sucked in to the engine is ambient pressure. If the MAP reads (current ambient pressure -0.02 BAR) at 7000rpm then this is as good as it gets without forced induction. you can stick a 80mm butterfly on and the cylinderhead will still be the bottleneck as the combined cross-section area of two inlet valves is still way, way smaller than the one of the stock TB
I do not argue that the mods make the car feel faster. if that floats your boat, these are definitely some mods to look into. For that reason I might go for it as well, if there weren't my concerns about loss of precision. I drive slalom events and the most important thing for good times is exact throttle control as you are basically cornering all the way through the course and loosing grip due to excessive throttle slows down massively.
one of the guys there also driving for years and always being fast in his integra type-r struggles to keep up with my times with his new focus RS because he can't control the throttle. characteristics of the turbo engine not helping as well...
also there is this guy in an S2000 who should have no problems winning the 2000ccm class with 240bhp, rwd and independent rear suspension. still, every time "vtec kicking in, yoooo" out of a corner his rear end kicks out loosing traction. it looks epic, it sounds epic... but it's quite slow
