200 cup dampers an upgrade for a 197?
Discussion in 'Suspension, Brakes & Steering' started by Jamie Smith, Jan 22, 2019.
  1. Jamie Smith
    Jamie Smith Paid Member
    30
    Hertfordshire
    Car:
    Clio 197
    Hi all,
    Just wondering if a set of 200 cup dampers will fit a197 and if these are seen as an upgrade over the 197 Cup items?
    Am I right in thinking the 200 cup units are slightly stiffer?
    Anyone made this change?
  2. Jamie Smith
    30
    Hertfordshire
    Car:
    Clio 197
    Also, would I have to change the top mounts to a later type if putting the later 200 cup dampers on?
    I’m reading that the later 200’s had a narrower top to the front spring so not sure if it’s even possible to retrofit 200 suspension to a 197??
    Sorry, I’m new to this
  3. john_walker74
    john_walker74 Paid Member
    523
    Milton Keynes
    Car:
    Meg 250 cup
    Early 200s have the same larger top mount design as the 197. My 59 plate 200 had the larger top mounts
  4. RSRowe
    RSRowe Paid Member
    264
    Car:
    Clio 197
    The difference between standard shocks and cup ones is like night and day imo.
    I run them with lowering springs and they're mint for track, but a little crashy on the roads.
    Jamie is right with what he's saying too. You'd need early 200 shocks to fit your 197.
  5. Jamie Smith
    30
    Hertfordshire
    Car:
    Clio 197
    Thanks for the replies chaps. I have the option of going for 197 or 200 cup dampers (early 200’s) as I’m changing them all.
    Any advantage of 200 dampers over 197’s or should I just stick with the 197 cup shocks? I think Cup spring rates were the same between the two?
  6. Doogle
    723
    Plymouth
    Car:
    BMW e46 330cd
    Ive done this, great idea as sharpens up the handling. Id say 200 Cup dampers on the rear I find too hard, I think 200 Cup front dampers and 197 Cup rear dampers would be good. It can be too stiff for a road car.
    Jamie Smith likes this.
  • Share This Page
