Hi I have a 2007 197 Clio
There is play in the steering ( it wanders and the initial turn is not instance) it failed the Mot on track rod end which had movement in them. You could move them up and down even when fully tightened. I replaced them with new one from Euro car parts ( checked no etc ) on fitting them I noticed they are not tapered, I did them up as tight as possible and re submitted for Mot which it passed.
The steering problem is still there i.e. It wanders and the initial turn is not instance. I jacked the car up ( both sides) and noticed play in the hub carriers more on one side than the other, the worse side track rod end slight up and down movement can be felt as before.
I have looked around the net for advice ( there's not much out there and came across u guys ). I have read in another forum that there should be some sort of collar that is used to fit the track rod end into the hub carrier ? Spoken to a Renault garage and specialist and they are not aware of this.
The car has have a new drop link inner steering rods, I have checked the bottom of the rack in side the car, I think the problem must be the track rod ends ???
I have looked at the official track rod end replacement and they do not appear to be tapered so can only conclude there should be this collars as mentioned before.
It driving me mad !!! Can anyone help please
Thank jason
Thank jason
