hi, just bought a clio 197, all standard atm, im wanting it lower as it sits to high for me. would putting 197 cup suspension springs on make it any lower/stiffer or will it be the same as the standard set up. cheers :thumbup:
Height difference is minimal, 7mm, would be abit stiffer though, 200cup set up would be better if you wanted it stiffer, if your want it lower go for h&r springs or eibachs, think Ktec do them?
If your car has Cup suspension I wouldn't go for H&R's as the ride gets a little crashy, otherwise if you have the non-Cup suspension they're not too bad. H&R's are also slightly lower than Eibachs and similar brands.
If you've changed springs before then you shouldn't have too much bother, if I remember rightly you may have to slacken-off the rear diffuser a little but don't quote me on that.
