Hello Community,
I have a question regarding the assembly clearances (diametral gap) for the crankshaft and conrod bearings.
I am not finding these values.
Can you recommend how much clearance is needed for the large bearing (between crankshaft and bearing) and between the conrods bearing sheel and crank pins?
Thank you in advance!
kalo86
kalo86
