I found the red option to be a pain in town when plodding along because it is very sensitive and makes the car judder when going over bumpy road. Either that or I can't hold my foot stable lol
Mate how about those c3 sprayers? Are they plug and play? Any pictures? Thanks
True, the red option is a bit too aggressive for town, especially when you have a 64mm TB like I do.
I switch it from time to time just for fun. It's a GREAT mod. Car runs so much better now...
C3 sprayers - they're great. No, they're not plug'n'play - you need to cut some of the plastic.
They fit almost perfect (1mm of the hood probably because of the rubber gasket in between that you can remove but I didn't want to).
Wanted to see what were my chances against a Golf V GTI Revo Stage 2+ (280bhp/420Nm) with Michelin Super Sport tires, DS2500 pads, S3 calipers, 312mm Tarox F2000 rotors & KW V3. He is SO MUCH faster in the straight line...
Considering the fact that I've started using Clio mostly as a weekend car, I haven't bothered much with the ride height. However - I drove the Clio for the last 3 weeks straight and it started to bother me the rear hight. I had problems with big bumps in the road - rear axle would sometimes hit the exhaust pipe, and the ride was uncomfortable.
Had the rear lifted by 1.6cm by myself, and discovered that the rear was slammed as much as it could go. hmy:
You can see how low are the springs. And still first OEM rear rotors after 90kkm.
BEFORE
AFTER
And now, the ride is at least twice as much comfortable than before. Unbelievable. :jase2:
Next in order was repairing the connector clamp leak between the Y-pipe and the Miltek decat, and the leak on a merger point between the centre silencer and the rear silencers.
Welding the Miltek exhaust mount after it broke.
Really disappointed with the Miltek build quality given in mind that this is not the first (and probably the last) problem with the exhaust.
