Occasional loss of throttle - 250 engine
Discussion in 'FI' started by glenn3, Apr 12, 2016.
  1. glenn3
    glenn3
    64
    Car:
    clio
    Hi all
    I am having an occasional loss of throttle when I coast up to a stop. The pedal can go straight to the floor but the car just idles.
    When you stop and restart the car the car reverts back to normal.
    I have been told that this is a fault that can occur when running the 250 engine. I have already changed the pedal and throttle body for another 250 one but no joy.
    Next step is to try and mate a R26 throttle body to the 250 inlet.
    Has anyone had any experience of doing this mod before? Would it be easier to machine an adaptor plate or chop down a 250 & R26 inlet and reweld with the R26 throttle body connected?
    Any ideas/help would be much appreciated!
  2. Sean197
    Sean197 RIP Albi :( Moderator
    3,299
    Fife, Scotland
    Car:
    Albi 197T - RIP, MK7 Golf GTD Sports Wagon
    Any fault codes showing on an obd reader?
    I'd be checking sensors before changing the throttle body.
  3. glenn3
    glenn3
    64
    Car:
    clio
    No it doesn't throw up any fault codes.
    After speaking to a reputable tuner, they reckon the 250 throttle body is going slightly out of range causing the fault.
  4. Sean197
    3,299
    Fife, Scotland
    Car:
    Ah ok. Well if you need a 225 inlet to butcher I have a spare one (bare)which I can sell you for a few quid.
  5. M77MWw
    M77MWw
    123
    Car:
    clio 197
    Sorry for jumping this but anything come of this? I'm having same issue and about to sort out fitting r26 throttle body so any info etc would be great
  6. Sean197
    3,299
    Fife, Scotland
    Car:
    M77MWw likes this.
  7. M77MWw
    M77MWw
    123
    Car:
    clio 197
    Cheers bro any info would be epic
  8. youngarthur
    youngarthur Paid Member
    225
    I run the 250 throttle body, without any problems. I would put it on a reader first. before doing anything else.I have found, something like a brake pedal sensor, can cause the dashboard to light up like a Xmas tree!.
    M77MWw likes this.
  9. M77MWw
    M77MWw
    123
    Car:
    clio 197
    That's interesting, I wonder what Glenn did to stop the issue he was having. I don't have any faults come up on the dash
  10. youngarthur
    225
    Glen had a map put on it, knocking power back to std 250map.( Only knew this, when car was remapped) This only covered it up, but did not cure basic problem, which was due to sensors, overheating due to fan wrong way round/thermostat/two bad solenoids/boost leaks/and quite a few other problems.I only bought it, because I knew what it could be like, once all the problems were fixed. Now all fixed, remapped, goes very nicely thank you!.
    M77MWw likes this.
  11. M77MWw
    M77MWw
    123
    Car:
    clio 197
    Thank you for your reply hopefully I can sort this issue
  • Share This Page
