intake
2 quick questions for those that know the answer....
ported / bigger TB yes/no
pros and cons
I have a v6 airbox setup
I remove everything in induction subject and just fit this...
I read that I should not disconnect the "system" in the intake aux hose????
The TB makes a nice difference. More grunt lower down the rev range and a nice extra bit of oomph higher up too. I don't know if anybody has done a dyno' comparison yet but it does change the feel of the car and the delivery of the power. Makes a nice noise too! :smiley:
If you stick the V6 Aribox on, you still have to leave the vacuum pipe connected that runs from the Inlet Manifold to where the secondary induction "trumpet" sits on the inner wing. You can remove the "trumpet" but you need to block off the end of the vacuum pipe after the sensor/actuator.
