Has your gearbox been replaced? Yes or no?
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by Digital Reaper, Sep 16, 2011.
Have you had the gearbox in your 197 / 200 replaced?
  1. No - I'm still running the original gearbox
    382 vote(s)
    74.6%
  2. Yes - I'm running a replacement gearbox
    130 vote(s)
    25.4%
  1. FishFart
    FishFart
    20
    Car:
    Clio 197
    49k miles here
    2008 model
    Original gearbox.
    Have problem puting it in 1st gear sometimes.
    Also if i rev high almost impossible to quick shift from gear 1 to 2.
    The rest seems fine
  2. Jimbob200
    Jimbob200
    6
    Car:
    59 rs200 clio black
    Hi, I believe I'm on standard box 59 plate with 60k on the clock had slight crunch into 4th at times replaced the fluid with shell 75/90 as suggested in the factors and now I struggle to select 1st when cold I have to select 3rd or 4th then it will select all gears.
    Any ideas?? Someone mentioned bleeding the system??
    Also are the gearboxes the same from 197's and 200's?
  3. Big Ben
    4,768
    Herts
    Car:
    197
    Elf NFP gearbox oil worked best for me
  4. Jimbob200
    Jimbob200
    6
    Car:
    59 rs200 clio black
    Thank you for the advice
  5. Chris
    Chris Bad cop Administrator
    10,549
    Needham Market
    Car:
    LY 200t
  6. peter
    peter POTM Winner - February 2017 Gold Member
    1,161
    b e l g i u m
    Car:
    RB7 #166
    +1
  7. Sherlock101
    Sherlock101 Paid Member
    33
    Oxford
    Car:
    Clio 200
    Mine's had the 4th gear synchro replaced (and clutch at the same time), done this year at ~50k miles, not by me thank god!!
  8. Jonny112
    Jonny112 Paid Member
    25
    Car:
    Rs 200
    Not sure if mines been replaced but 56000m 2011 200 seems very happy still no issues touchwood
  • Share This Page
