On my way to work this morning i got just outside the gates and when i changed into 4th i felt a bit of resistance as such through the gear stick. So i muted the music and changed back into 4th. It had no trouble going into gear at all but made a slight noise, more of a squeek rather than crunching.
Anyway left it and thought id see if it done it on the way home ... But nothin on the way home (15 miles). Went to get petrol and took it for a drive and again still nothing but then on the way home i felt it again. The only way i can describe it is as if its metal on rubber if this makes sense as its not struggling for gears or anything just makes a sort of squeek. When i happens it also does it in 2nd but no other gears apart from 4th and 6th. I also noticed it only does it when the car is warm.
Ive drove the car for about 40 miles since and it hasnt happened again and when it does do it, it only does it a few times and then goes away so im abit confused.
Seems as if something needs lubricating bt id like to know what were peoples first symptons before they had gear box issues.
