it may be the tips hitting the diffuser, my car did this and got a garage to cut the tips a bit and all is fine now, need to make sure there allingned properlly because the standard rubber mounts are not good and make the exhaust pipes more alot.
Same as mine but i adjusted my yozzasport by adjusting the two mounts either side of the backbox, which have a slight play for adjustment in the mount brackets.
