Decat questions
Thanks guys. Yeah still got the main cat in place exhaust is all standard. Will the mounts need doing at the same time, just I've got the car booked in tomorrow and don't think they would come in time. Any recommendation on what mounts to buy as well?
Have the centre exhaust mount removed and checked. I ordered a replacement and was given an upgraded part from the dealer. Inexpensive aswell
The mount people talk about using is usually the Vibra technics lower torque link, however there is an option to use a Powerflex bush inserted into the standard torque link and also the upper torque link. Plenty of discussion on here if you search those terms.
Personally I run the Vibra lower and Powerflex upper, it was harsh when I fitted it mind. However when Tech 1 did the manifold and re did everything the harshness went, so I believe the angle and position the engine is at when you finally torque the bolts makes a difference.
