Brake calliper bolt torque setting?
Can somebody confirm the torque setting for the front brake calliper bolts?
I've got the workshop manual and it says in Nm - 110 then its got in bracket next to that 170.
So is it 110Nm or 170Nm?
If someone could confirm asap that'd be great as I need to get it all back together!
caliper 170nm
wheel bolts depends on which literature you consult - its either 130nm or 140nm
I used to go for 140nm and do the locking bolts at 110nm
