200T Problems
Discussion in 'Clio 200T Area' started by Gilmos1, Nov 30, 2015.
  1. lewisflintham
    lewisflintham POTM Winner - November 2016, August 2017 Platinum Member
    669
    Swanwick, Derbyshire
    Clio EDC LUX - Cup
    Mine has developed this crash/clunk from the front. Seems to happen if you drive up a drop kerb. It almost sounds like something on the suspension is loose and vibrates with an accompanying crash.
  2. Chris
    Chris Bad cop Administrator
    Sounds similar to what I had and it was an engine mount.
    lewisflintham likes this.
  3. sevenfourate
    sevenfourate Devotee of OCD Paid Member
    Lowestoft, England.
    Racing Blue RS-200
    Snapped spring is a possibility.....
    I recently had the same - (Not on a 200T mind you) and my mechanic said to me they often go in winter. The cold is just enough to make a fault / crack brittle and "BANG"....away it goes.
    Good luck.
  4. lewisflintham
    669
    Clio EDC LUX - Cup
    Thanks for the hints guys. I'll have a look at the spring first and if it's not that, I'll get it booked in to Renault.
  5. lewisflintham
    669
    Clio EDC LUX - Cup
    Update:
    Crash/clunk is now fixed.
    It's had two new lower wishbones and all is well with that fault now :smile:
    Knock from rear.
    Had some sort of spacer fitted to the shock mount (and some adjustment) from what I understand (which is probably little, plus they hardly want to tell you anything).
    Creak from driver's window.
    This has been fixed by lubricating the top of the door seal. The bit that is on top of the window, but sits on the underside of the roof/door opening.
    Tailgate creaking.
    This didn't get fixed. They changed the bolts and lubricated the boot catch, but it still creaks on slanted road manoeuvring. They suggested a wax based polish on the seal. If this doesn't do it, they'll replace the seal.
    Vibrating headrests.
    Now fixed. The adjusted the gap between the legs, and I believe they've fitted some foam pads
    Buzzing from behind steering wheel.
    Still not fixed. They've replaced the steering angle sensor, as that was making a noise too. It seems that the buzzing might actually be the left hand circular dashboard surround. So, it's either furniture polish or WD-40 time soon I think.
    Finally, thought it was worth a mention, the brake pedal squeaked every time you pressed it. I just attacked the mount with WD-40 and it's all sorted.
  6. Micah
    Micah Clumsy McButterfingers Moderator
    Kent
    Clio 220 Trophy
    Jeez, puts you off Mk4 ownership!
  7. Arran
    Arran I Love Lamp Platinum Member
    Wolverhampton
    Clio 200t Lux
    My boot creaks when the car is on a slant. Not a big deal imo. The passenger seat head rest rattled the other day. I pushed it down a bit more. Sorted. I have got an annoying rattle from the passenger side side plastic which I'd like to get sorted if I can.
  8. Jimmy
    Jimmy Good cop Administrator
    Blimey, that is a fair old list of issues! A bit up and down with the results, and as Micah says, surprising for a newer model. No car is immune to it though I guess!
  9. lewisflintham
    669
    Clio EDC LUX - Cup
    It had a new led running light just after I got it (2 years old) as it was permanently dim too.
    Obviously it had its spoiler recall too.
    I've just remembered, when it went in on Monday, they've done a recall on the wiper arm linkage.
  10. nutnutwelshman
    nutnutwelshman Spa-tacus Area Rep
    2
    Both my cars driven like Miss Daisy at all times never had a problem touch wood
  11. Jimmy
    Is that the Miss Daisy that often gets mistaken for a racing driver?? :tonguewink:
  12. nutnutwelshman
    2
    No me old and slow @Jimmy everyone knows that
    Jimmy likes this.
  13. Jimmy
    It's just as well there's not ample photographic evidence on the forum of you hooning it round Spa then Kev :smile:
    Oh....wait a minute....
  14. nutnutwelshman
    2
    That's my baby brother @Jimmy
    Jimmy likes this.
  15. nutnutwelshman
    2
    So after Sean's positive feed back from Spa you coming in October bud
  16. Jimmy
    It's on the list Kev and I'd love to join you some time, I can't see it happening this year though unfortunately buddy.
  17. nutnutwelshman
    2
    N
    Next year then can you get Mondays off
  18. Arran
    Wolverhampton
    Clio 200t Lux
    What was the wiper arm linkage recall? My wipers are shite, they sit really on the screen if there is much wind resistance or the screen isn't wet enough. When we bought he car, on the test drive the wiper was hitting the a pillar when on full speed. Renault Wolverhampton stopped it doing that, but there seems to be far too much free play in the mechanism.
  19. lewisflintham
    669
    Clio EDC LUX - Cup
    The guy didn't say much about it, apart from "some cars have been reported as the linkage coming loose". He mentioned about the long bar that links the two. Hope that helps you a bit.
  20. lewisflintham
    669
    Clio EDC LUX - Cup
    I've just checked and my wipers hardly wobble at all (maybe a tiny bit). Not so you'd say "there's a lot of play in those".
  • Share This Page
