Been speaking to Matt about this and he tells me the R3 box was designed to retrict power anyway. Most prob to ensure that all cars run the same power?
Didn't expect that mate! Were they both from the same rollers?
christ your car made good standard power!! did u spank it from new lol? think a re map will sort it, im gonna match my inlets at jamsport then re map from tdf to iron it all out.
Is there no other way to get a cold air feed in to this ?
Sorry about results btw mark I'm sure with a decent air feed and a remap youllsee 200
surely its cus the air temp on the second run was higher?
Also do you have a link to this exhaust you speak of mate
Can it be brought in the uk ?
I bet it's a nightmare to fit though . :-( and would probally throw up error codes on dash right ?
What are the gains ?
Would this then be run with a complete standard system there after ?
I think you need to drop the front subframe. I doubt error codes will come up with this exhaust mod alone. Doesn't happen with a de-cat.
There is only so much air you can get into an engine and exhaust out, so without going down the turbo or supercharger route you will have to change the throtle bodies and cams for real gains.
Renault spent a lot of time and money on this engine and I have tried many exhaust /intake combinations all for little gain over the standard Renault items..
And for those looking for much higher top speeds gearing would need changing.
The problem with large air boxes is the air pulses are out of tune IE slower than the original ,so while you may feel a bit more flexabillity or even bottom end power gain you will loose top end .Pendulum chambers and inlet manifolds all come into play to get the most efficient burn.
The air temp on the dyno run should have been ok as the cars ECU should deal with it and they should have factored it in for the Dyno if not.
In the early '70's we managed to get 93bhp from a 54 bhp engine (MGB) but the intake mainifold tubes we made ended up 32" long.Loads of other mods such as distributor carbs etc.
We teach a lot about induction here but its a very big subject and not fully understood how much time money and effort goes into it .
My car is totally standard ,after spending thousands on my first 197 for not great gains .
If I do anything to this one It could be brakes ,Chassis then maybe a turbo.
WOOO My new suspension is on a pallet and on its way to the UK !
nice one Mark i bet you cant wait to get them fitted, lol :tongue_smilie:
White 197cup Ellesmere Port | Spotted | 1 | |
197 vs 197cup | Clio General Chat | 1 | |
D | 930Tech - r197cup | Spotted | 1 | |
Happy birthday Jib197cup | General Chat | 4 | |
hi all! - 197cup | New Members | 25 |
