Hi, everybody. I want to install Rays TE37. The configuration plan is as follows: Rays TE37 ET40 17x7.5 Michelin Cup2 225x45 It is also possible I will install coilovers with adjustable supports, and will be able to adjust the descent-collapse. Will it fit? What are the pluses and minuses in this decision, I want to understand whether more result reducing weight the wheels on the track. Will not deteriorate if the operation of the vehicle? Thank you!
You need to check the bolt spacing. I believe its 5x108? I have 225s on KW Clubsports, but the car is set at min drop and I dont have any rubbing issues, but I am also running the stock Speedlines and no spacers.
Thanks man! TE37 really have version with PCD108, and I found it. Here https://a310vf1600.exblog.jp/20577473/ some foto with Clio on TE37
As above, et45 is the most you want to go on a 7.5x17 wheel. Et45 will stick out a little too much and increases the chance of rubbing the arches if lowering the suspension.
