Of course it depends on engine temp and that's what i'm saying, if the car is hot enough for the fan to work while its underway and breathing air, it sure would be hot enough for the fan to keep working when it comes to a hault and therefore not turn off when you turn off the engine. Unless it's engine driven which i highly doubt. So my sound must not be fan-related.
I'm no mechanic so it was a bit of a guess with it possibly being the fan to be honest. If the engine is hot after a drive and you come to a standstill, my (limited) understanding is - because the engine is no longer getting any cooling from moving air, the fan kicks in to draw in air whilst idling?
If you then switch the engine off, I assume that the fan would also wind down (possibly the whine you've experienced). The engine wouldn't necessarily require the cooling from the fan as it's no longer operating?
I might be wrong, so if anyone with better knowledge than I have puts me right, fair enough![]()
You pretty much just typed out an identical post to what I wanted too![]()
great minds and all that! We still might be totally wrong about what's causing the whine though!!
I see what you mean now, but the sound doesn't just get quieter , it disappears altogether. Fan sound is very distinctive anyway and i am sure it's not that. Sorry for over-analyzing :bash:
H | High Pitch Whining Noise | Clio 197 Area | 8 | |
B | Whining noise on start up | Clio 197 Area | 0 | |
Whining on cold start | Clio General Chat | 3 | |
Whining/whistling noise | Engine, Gearbox, Exhaust and Air Intake | 26 | |
Squeeking/Whining | Clio General Chat | 2 |
