Where's the fuse for fuel pump
Foxspeed "the new red baron" Moderator Jul 13, 2013 #3 terminal 2 of the brown (12 track) multi-plug is supply to the pump Last edited: Jul 13, 2013
Foxspeed "the new red baron" Moderator Jul 13, 2013 #4 you should be able to hear the pump build pressure before you start it... if you cannot hear it try giving the fuel tank a good thump!
Foxspeed "the new red baron" Moderator Jul 13, 2013 #5 if the pump does buzz and there is pressure in the fuel lines then have a look at the tdc sensor...
