Where to buy gen. Brembo front pads?
parkincj
As title says, I'm after buying some brembo front pads for a 197. I've spoken to next day brakes who don't stock the item anymore and I'm a little cautious with eBay. Any suggestions?
I was just about to say Nexyday as they're the cheapest by a longshot.
I'll go nextdoor after work and ask my Mechanic where he got mine from.
Part number P60836 - I'd get someone to clarify this is the right Brembo number but I'm 99% sure.
EDIT: Try ringing Karl at SMC
http://www.clio197.net/forum/showthread.php?28800-Only-Way-To-Contact&p=403116#post403116
EDIT: I'm pretty sure these are the correct part number, and I believe we get discount from OPIE.
http://www.opieoils.co.uk/pv-103801...-for-both-wheels-on-1-axle-brake-pad-set.aspx
EDIT: Nextdaybrakes do sell them, they must have removed the Clio pads as they where incorrectly listed on their site from previous problems, same as the Megane sport.
http://www.nextdaybrakes.com/brembo...20-renault-sport-pn-p68036-pair_p22312976.htm
Or [MENTION=8494]smithandroper[/MENTION] aka brian leighton garages 01430 430717 ask for Carl Smith or Graham the parts manager.
Plus if you buy them from Opie Oils this weekend you can get an extra 20% off
For limited time only 20% off everything!! Simply use voucher code DEAL20 when ordering via our web site Opie Oils or give us a call on 01209 202944 Monday to Friday 8.30am 5.30pm
If you want genuine Renault Brembo pads you will have to get them from a Renault dealer direct. The rest are made of cardboard and no where as good as genuine Renault even though they are genuine Brembo. The quality and compound are not the same as, Brembo are licensed to only make and sell that pad through the Renault dealers.
I think we have some pads in stock I will check tomorrow or if anyone wants a price PM me a contact No and I will get parts to ring you.
Put it this way would you put £24 pads on a 140mph car?, it's like fitting £30 tyres, if it's just going to sit in Burgerking car park, go for it. Genuine pads are not expensive, considering Ford want £240 for there pads for the Brembo calipers.
Got some from opie oils, slightly confused as the nextdaybrakes website said the part code was specifically not for the 197 and when I called they confirmed, but it's the same part number at opie.
Thanks again for all the help!!
