What Else Would You . . . . .
MarcB
What else would you change / do while getting the Timing Belt done.
So far my list is as follows using all genuine OE Renault parts.
Timing Belt Kit
End Caps
Defacer
Water Pump
Aux Belt Kit
Crankshaft Pulley Bolt
Full Coolant Flush / Change
Engine Flush With New Oil & Filter
Sump Plug
Air Filter
Pollen Filter
Spark Plugs
Reactions: littleg78
make sure the crank damper pulley is ok...there have been issues with them cracking and coming apart
Reactions: suj
