Hi guys,
I have a leak which seems to be getting in the bottom of the passenger door.
I've seen a lot about door drains etc but I can't find any pictures to check all the drains I should be checking (just generally looking for holes that look blocked).
I've replaced the door sills (rubber at the front of the rear glass). Cleared the scuttle drains and cleaned the area.
Any guides/ pictures of where to check. also should i look into stripping the door panel and checking there as I've seen mentioned before. based on the attached picture, could it be a place to check or more drainage/rubber seal? You can see in the picture where its coming in, even a pit at the back owned of the door too
Thanks in advanced.
P.S. I've took it back to where I bought it 3 times to fix the leak and every time they said they have but they havent! time to take matters into my own hands.
Thanks in advanced.
