Water build up?
MikeLYR27
Supercharged Platinum Member
I was adjusted my KW's yesterday and found the top of 1 strut in a pool of water?! Is there a drainage hole clogged? The opposite side is fine. Anyone hat the same thing and know how to fix it?
Cheers :smile:
In the scuttle panel? There are rubber drainage pipes at each side that are prone to getting clogged, when I cleaned mine I did it from underneath, wheel off, rear wheel arch liner out, then poked up with a screwdriver. I had previously tried getting it from above but without any success.
Karcher, power, solved.
I do mine EVERY TIME I was the cars.
Yeah thats the one. The rear arch liner, so it drains there then? not the front?
Cheers for the advice guys!
It drains at the front under the bonnet where the plastic trim runs the width of the windscreen.
There are some slats that are supposed to prevent dirt and debris build up with a small drain in.
To fully get to them you have to remove the panel but provided you keep on top of it you will be fine.
Sorry, to clarify it is the rearmost front wheel arch liner. The front liner is in two pieces, you need to remove the rearmost one.
