Hi
Can anyone help with issues i have re the excessive wear on the Recaro seat bolster ( mainly drivers side) that i have experienced on my 59' plate Clio cup?
I have heard that these can be a problem and i have reaised the issue with my local Renault dealer but they are stating that it isn't a warranty issue because its ' wear and tear' ! bearing in mind my car has only covered 14thou...
The lastest from them is that they will 'repair' it on the basis of 'good will' and not under warranty, which leads me to a couple of questions you guys may be able to helps me with: Can it be repaired to look factory or as i suspect is this a cheap way of getting out of having to replace the whole seat?
Any others owners out there had or having the same problems??
Also another problem i have with the car is both side windows will have to be removed - they are bonded in!! to replace the seal that closes the gap betwwen the door frame and window that has disintegrated - not really very happy bunny that these windows will have to be removed to say the least..
Great car tho....grrrrr:thumbup:
So please help if you can , thanks in advance
ps See you at Oulton if you're going ...
