Just a note for those of you that have fitted braided lines. I fitted mine a few weeks earlier and checked everything was clear and that nothing rubbed. I took my wheels off the other day to find that one of my brake lines had been rubbing on the rim of one of the wheels. What I have concluded is that the pipe is able to move in the plastic sheath under the clamp on the hub. This allows the line to rub on the inside of the wheel on full lock.
To fix this I have replicated the original setup by adding another clamp, there is now no way that the pipe can move now. The pipe now is clear of everything. Had I not checked this I could of had a serious problem.
If you have braided lines it will be worth having a look to see if you don't have a similar issue.
Pictures
I hope this is of some help
A picture of what I used to drill the holes with
Pictures
