Violent front end shaking
cliovirgin
Gold Member
Need help please guys ! Above 3500 revs, my car is shaking to bits. The massive vibrations are felt through the steering,peddles and chassis. What can be causing this ?????
Sounds like a mount has broken. You could jack it up and get underneath but it's really best to get it on a ramp.
Gearbox,and torque mounts fine/ newish. The top engine mount has just been changed, but has not cured things.
All balanced yet again, to make sure not the problem, no,not helped. Steering is spot on, car never wanders.Avoid potholes like the plague !!!!
Have you checked the exhaust manifold? Driveshaft is another possibility - check the shafts and also the hub nuts.
Manifold, ????, don't think is the problem. Yep new N/S driveshaft replaced, O/S is ok, not cured.Hub nuts and discs checked, all are fine.
When you say it starts at 3500 RPM, do you mean it does it when standing still, just revving the engine causes it, or is it road speed related?
Still awaiting some hardcore advice ! Could something be wrong engine wise or the flywheel perhaps ?
Have recently had slight misfire. sorted with new knock sensor after reading the fault codes. That had caused engine vibrations, which may have in turn caused this problem ? The car is undrivable,both these things happened a week or so after fitting new discs,pads,calipers refurbed and clutch bleed. Don't think is related, as all seems fine.
Manifold/exhaust pressure somewhere? If it's got a hole or seals have gone or something like that it could probably cause vibration?
